which is better stock 98-99TB or stock00-02TB?
1 Post
Originally Posted by Z28XTC
Which is better and is there an advantage or disadvantage to putting a TB from a 01ss 0n a 99Z28??
Other than that they are identical
Originally Posted by camaroextra
The throttle cam is different, the 99's cable doesnt pull as far and the tb wont open all the way.
1 Post
Originally Posted by Intragration
If what you're saying about the '99 tb not being able to open all the way is the same thing that I'm thinking about, Camaroextra, there's a mod to fix this too, where you just slightly bend the tab that contacts the stop until the butterfly can open 90 degrees.
You also definatly dont want to mess with the tab on the cam, of you bend it to allow more throttle, it will hold the throttle open agains the idle screw when your trying to idle, that was a newb mistake i made myself when i first got my car. (car started at 3 grand)
I was referring to the bumpstop mod that allows the butterfly to open completely, in response to your post that the '99 TBs won't open all the way. You only need to bend it so far, just so that the butterfly is open to 90 degrees at WOT. Then, if it idles too hi, I suppose there's an idle speed adjustment screw. I didn't have a problem with that. I guess it depends on how far off your butterfly is to begin with.
