Drag Racing Tech
Drag wheel question
Old 04-28-2006, 11:37 PM
Import Patrol
CrawlinWS6's Avatar
Default Drag wheel question
I already posted this in the wheel and tire section, but thought I should post it on here as well.
I run 28x10.5 hoosier slicks on 15x10 prostars. At what point should i put screws in the wheel to hold the tire to the wheel. I will be pushing close to 600rwhp, and was think if I should do this before my next track run?
Old 04-28-2006, 11:44 PM
lafnlt1's Avatar
lets say you don't with that type of power, you will be the only person at the track that does a burnout with the tire staying still, the rim will spin that much. also if you run a inner tube without screws, it will rip the stem off vary quickly
Old 04-28-2006, 11:50 PM
Import Patrol
CrawlinWS6's Avatar
I ran last year, with out them. With about 60 less rwhp. With no probs. BUt I am gunna put them in fro added insurance.
Old 04-29-2006, 11:41 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
I don't run rim screws.
Old 04-29-2006, 01:24 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
I didn't screw them until just recently, but they were spinning on the wheel quite a bit. I used that as my parts breaking cushion
10.6s @ 125mph w/1.42 60ft
Old 04-29-2006, 01:51 PM
LS1Tech Co-Founder
I've seen an inch of movement here and there, 1.35 best. I keep them at 12psi typically, lower than that and they miight move more on the rim and the car handles like crap at the end of the track.
Old 04-29-2006, 05:02 PM
smoknta's Avatar
Just mark them and see if they are moving. If they aren't moving, I would not screw them.
Old 04-30-2006, 12:27 AM
Import Patrol
CrawlinWS6's Avatar
Thanks for the input. I'll hold off for the time being, and check to see if they move any.
