florida juicers...
Old 04-28-2006, 11:42 PM
Hennytime's Avatar
Default florida juicers...
its getting damn hot out and this is going to be my first summer with the bottle. is it just me or is it weird to walk out at 8am and find my bottle at 1000psi, and then walk out at lunch and find it at 1400psi, what the hell do you guys do to get the pressure back down, hell when i go to the track im going to have to bring a cooler w/ ice to chill the bottle
Old 04-29-2006, 12:29 AM
Loudmouth LS1's Avatar
Hell no, that ****'s the best, hook her up, open her up and ****** let her rip, it hits hard!!!!
Old 04-29-2006, 12:31 AM
97blkz's Avatar
let some line pressure out?
Old 04-29-2006, 12:53 AM
Senior Member
Country Boy's Avatar
Dont ever leave the bottle open if your not around it. I did it once on accident and when I remembered, the gauge was peaked. I think it was right around the blow off point (2500-3000 PSI)
Old 04-29-2006, 01:37 AM
mrr23's Avatar
if the gauge is on the bottle valve assembly itself, like NX, it doesn't matter if it's open or closed. keeping it closed will aide in keeping the n2o solenoid from having too much pressure against it. some n2o noids won't open above 1400 psi. and the extremly high pressure can damage the needle and seat in the n2o noid.
easiest thing to do is to crack open the line if you do not have a purge solenoid. and you may still have to crack the line open if the pressure is too high for the purge solenoid to open.
Old 04-29-2006, 05:57 PM
blacktransam's Avatar
make sure bottle isn't in direct sunlight.. and keep a window cracked
Old 04-29-2006, 06:41 PM
redline2k's Avatar
With mine in the rear window i have to keep them covered with a blanket during the day. When I had it hidden it was never a problem. I also have my windows tinted with 13%
Old 04-29-2006, 08:11 PM
Reject's Avatar
wow dindt know that, couldnt you just like purge it out or somthing?
Old 04-29-2006, 09:40 PM
chpmnsws6's Avatar
Doesn't NX make a blanket that heats OR cools the bottle, keeping it at its best presure?
Old 04-29-2006, 10:02 PM
terry s's Avatar
It is called Fire & Ice. It heats and cools the bottle.
Old 04-29-2006, 10:26 PM
Hennytime's Avatar
didnt think of puring out some juice, hurts me though since its almost as expensive as gas...i rmeember when it was the other way around lol!
