500 hp and two blown clutches
Old 04-29-2006, 08:25 AM
bernard shortt's Avatar
Default 500 hp and two blown clutches
i need a clutch to just hold 500 hp in less than 15 passes i have killed a mccleod street twin and a carolina stage 3 clutch
i need to know what kind of clutch will hold my car this is starting to be expensive
Old 04-29-2006, 01:41 PM
SSPerformance's Avatar
whos installing them.....and do u no ho to drive? my friends has the twin disk in hi 700rwho ta and no problems
Old 04-29-2006, 02:18 PM
Jimmard's Avatar
You can try a textralia...
Old 04-29-2006, 04:41 PM
madmaxz's Avatar
how in the hell did you blow up a streettwin?!
Old 04-29-2006, 04:48 PM
ozws6's Avatar
Are you slipping the clutch at launch when at the track? The McLeod won't last very long if you're slipping the clutch, it generates too much heat.
Old 04-29-2006, 06:38 PM
Jimmard's Avatar
I think they say that you can slip a textralia out of the hole and it'll take it.
Old 04-29-2006, 09:59 PM
yes i know how to drive and no im not slipping it at all,MORE PERFORMANCE installed the carolina stage 3 and TEA installed the mccleod street twin,just popping it at 4000rpm and went 5 passes 1/8 mile track waiting 30 mins between runs ,and while burning out killed it dead
Old 04-29-2006, 10:22 PM
lowws6's Avatar
I know what you mean, I am on my 6th clutch in 38K miles. I just installed a spec clutch this week hope this one works.
Old 04-30-2006, 06:15 AM
what stage of spec did u use this time?
Old 04-30-2006, 12:20 PM
lowws6's Avatar
This time i went with the stage 3+
Old 04-30-2006, 07:03 PM
LS1Tech Sponsor
Slowhawk's Avatar
SPEC stage 5 will last. Also if you burn a clutch on a burnout it means you need more water on your tires and pop the clutch,don't ride it
Quick Reply: 500 hp and two blown clutches
