STS ?'s
STS ?'s
I have a 2000 SS M6 w/ 8k on it. I thought about going with an STS rear mount kit. What else would I need to run this safely or does the base kit include enough to run it for a while until I can afford the rest of the stuff? Any and all input is appreciated.
LS1Tech Sponsor
you will want injectors and an inline pump, 42 lb injectors and a walbro inline pump will do. Youll also want a professional dyno tune and some guages to keep everything in check, fuel pressure, and a wideband O2 which would help monitor the best. Hope this helps! Also if you have extra cash or later on you might want to check into valvesprings and pushrods to help with valvefloat.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
