What size true duals do ya'll have?
Old 04-29-2006, 12:11 PM
14 Second Truck Club
Hemi Killer's Avatar
Default What size true duals do ya'll have?
Please list the diameter of the pipes in your true dual exhaust set-up. And please list why you run what you run (i.e. more displacement, blower, nitrous, etc.) Thanks.
I know that probably most people on here run 2 1/2" or 3". I'm trying to decide on wether or not I should step up from a 2 1/2" dual exhaust to a 3" dual exhaust when I get my 382 in. I've got to have the cats where I live (due to dumb-*** neighbors), so that plays a big part in it. Kinda think I should go bigger, curious about the loss of back-pressure and the effect on the very low-end.
Old 04-29-2006, 12:17 PM
99Hawk262's Avatar
2.5" here. I'll never make enough power to go bigger. Some say 2.5" is only good to 500-600 bhp. Don't 03-04 Cobras run 2.5" exhaust? I know they make some big power....500-600 rwhp.
Old 04-29-2006, 12:39 PM
98LS-WON's Avatar
3". I have to be careful over speed bumps.
Old 04-29-2006, 12:59 PM
tbs98z's Avatar
3" Lane's here
Old 04-29-2006, 01:15 PM
What's a Sticky?
97MysticZ's Avatar
Do you have a pic of how your 2.5" exhaust is connected to your headers? I just got my headers and I have a 2.5" true dual setup, but I'm trying to find how everyone is connecting the two.
Old 04-29-2006, 01:43 PM
99Hawk262's Avatar
I had flanges welded to the collectors and the exhaust. They bolt right up and removing the exhaust is a breeze. I also had flanges welded right behind the mufflers so I can take the under-axle sections off for maintenance or if I decide I want that sound from dumps.
Old 04-29-2006, 01:47 PM
SSU's Drunk Typing Whore
Lithium's Avatar
3" from a member on here.
Old 04-29-2006, 01:52 PM
What's a Sticky?
97MysticZ's Avatar
Did you have it all done at an exhaust shop? I am gonna do it all in my garage, and the duals are already made, but I don't a welder. I'm thinking of having a shop weld the flanges on my headers, and then I will bolt the other flanges to them (with no exhaust on yet), then I can set the exhaust where I want it and mark the dual side flanges and dual pipes, then I can unbolt the flanges and have them welded to the duals according the marks.
Old 04-29-2006, 02:27 PM
99Hawk262's Avatar
All done at an exhaust shop. They did a hell of a job too. I'd take it in and have them put it together. That way there is no chance of error. It'd be done quick too.
Old 04-29-2006, 04:34 PM
LS69TA's Avatar
I've had 3" before, and ground clearance was decent, just had to be careful on speedbumps. I'll probably go with 2.5" on this T/A since I lowered it, unless I get some Dr. Gas oval 3" pipe to gain some ground clearance.
Old 04-29-2006, 05:36 PM
99Hawk262's Avatar
Oval pipe would be real nice! That's an idea worth pursuing.
Old 04-29-2006, 06:26 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
2.5 x pipe all da way out da back.
Old 04-29-2006, 08:33 PM
Strahley's Avatar
2.5" here, which is plenty big
Old 04-29-2006, 08:46 PM
chocolatemilk's Avatar
2 1/2 under the axle. with no cats. mainly ground clearence. but about to go back to y pipe cuz my neighbors hate me.
Old 04-29-2006, 08:48 PM
Strahley's Avatar
Oh I'm sure they do things to **** you off too, don't worry about them
Old 04-29-2006, 09:41 PM
jmm98LS1's Avatar
2.5" dumped at the axle
Old 04-29-2006, 09:46 PM
blackbird00's Avatar
3inch at the axle
Old 04-29-2006, 10:45 PM
JEB Garner's Avatar
Duals with 2 1/2 inch pipes going over the axle with Noise Cancelling, straight through design mufflers at the rear, one on each side of the tub. That way I get the power of the Straight through exhaust flow but without all of that neighbor and law complaining noise.
Old 04-30-2006, 01:47 AM
What mufflers do you have?
Old 04-30-2006, 01:59 AM
s346k's Avatar
i am running 3" with x...i went with 3" over the 2.5" simply because i will be stepping up to a VERY large cam that will benefit greatly from the scavenge effect...also, low end doesn't apply to me as i have a big stall auto.
