Driving on different injectors????
I am having a 93 Z28 Dyno'd tomorrow and Im wondering if It will be driveable with 36 lb injectors vs. the 24's that its programmed for? The dyno shop is 20-30 minutes from me and I can go slow on back roads if I have to. I just dont feel like getting my trailer and going all over town just to tow this thing.
I would swap the injectors at the shop, simple enough project.
You are talking going half again the programmed size that will massively overfuel likely to the point of detonation and definetely to the point of washing the oil off the bores and contaminating the oil not what you need just before wailing on it on the dyno.
Originally Posted by TAQuickness
I drove mine untuned for ~35-40 miles to the tuner. You should be fine as long as you don't get a heavy foot
Honestly, going from smaller to larger injectors, no problem, it will just run rich in open loop. In closed loop it will be fine, but the fuel trims will be down around 80-90. Won't be a problem. Don't just let it idle to get into closed loop, as it will be dumping fuel no knowing and will wash the cyl walls down. Change the oil afterwards.
Think of it this way, your injector constant stock, is around 24-25. The PCM is calculating fuel for your engine expecting xx cc of fuel out per pulse. Now, you put in larger injectors, for each pulse they are putting out xx+y cc of fuel. That is roughly 50% more fuel. So at cold start you are running 12:1 AFR, you would be running like 7-8:1.
Wanna bandaid trick? Put a resistor in the CTS that is around 80C temp instead of what it is now out (assuming you live where I do and it is cool out). Then it will lean it out accordingly. As soon as it gets into closed loop, around 90-180 seconds later, remove the resistor and plug it back in to the sensor. Yes, it is impractical, I know. Just a way to fool it while in open loop.
Just drive it and get into closed loop ASAP.
The pcm can not compensate for 50% too large an injector, as others and myself already said going from 24 to 28 is one thing this was another. At least the guy with the question was smart enough to filter out the intelligent answers and follow them.
