Tested the CheaTR & Patriots at the track
Old 04-30-2006, 01:31 AM
Threesixes's Avatar
Default Tested the CheaTR & Patriots at the track
My 1st time at the track with my patriot heads and Cheatr cam in. Im not sure what to think. I couldnt get a good launch all night and the car is trapping the same on the bottle as it did before the heads and cam, but the ET is better. NA time was WAY better than before.I havent been to the track in a year and half and it showed. Also I dont think my N20 bottle was all the way full. Here are the results through stock manifolds on mediocre 60 fts:
N/A: 12.39@113.44 -1.911 60 ft
100 shot: 11.60@119.00 -1.70 60 ft
My car before the heads and cam ran an 11.86@119 with a 1.7 60 ft but the best it ever did on motor was a 12.90, so im not sre what to think. I know I need to work on my 60 ft times, I was either bogging or spinning all night. Most 60s were 1.9s and 2.0 on some worn out ET streets. Also there is a hesitation between the launch and when the N20 hits, so there is more time to be found, Im sure.
Old 04-30-2006, 02:11 AM
Flash99's Avatar
Good times, what you really need is to drop that 60ft and you'll be dipping low 11's for sure. As far as the cheatr cam, does it really sound stockish? Idle wise etc?
Old 04-30-2006, 02:27 AM
Threesixes's Avatar
Not even stockish.The idle sounds completely stock. Now the valvetrain is slightly noisier, but that just helps hide the annoying piston slap I really like this cam. At one point I looked down at the tach and it was at 6900 rpm and the car was still pulling. I was like "oops, I had better shift", lol.
Old 04-30-2006, 08:35 AM
CHRISPY's Avatar
great times for stock manifolds and stock drivability! Good sixty and you have 11s on motor EASILY
Old 04-30-2006, 09:12 AM
bad95killer's Avatar
Nice N20 ET man esp. on stock manifolds
Keep it up....practice , practice & practice .
peace
Old 04-30-2006, 11:49 AM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
peace
Ditto.
Coach
Old 04-30-2006, 04:46 PM
Threesixes's Avatar
I forgot to mention that my timing tuner was set to turn the n20 off at 6k, I forgot to raise it after getting the tune. N/A Im shifting at like 6.5K, so when I raise the RPM setting of the N20 I may pick up some time there, Im not sure
