Abs INOP? What the heck?
Old 04-30-2006, 01:01 PM
ReD95LT1's Avatar
Default Abs INOP? What the heck?
Hey guys yesterday when i got in the car i started driving and look at the gages to see that the ABS INOP light is luminated and the e-brake and low traction light are flashing.
My brakes worked fine all night and the car was not acting weird at all, when i turn the key right before the on position, i can hear the ABS relay ticking in the fuse box, what the heck does this mean?
Also all the lights stop when the car is stopped, but sure enough when i continue going they do the same.
Old 04-30-2006, 01:50 PM
dhdenney's Avatar
Sounds like a short or bad ground. Need some more details. Does your car have traction control? Check your third brake light also.
Old 04-30-2006, 02:10 PM
ReD95LT1's Avatar
doesnt have traction control,
i think its the relay in the fuse box because when i turn the key it ticks loudly??
Old 04-30-2006, 02:15 PM
dhdenney's Avatar
If I remember correctly, it should be the same relay for most of the crap under there. Switch em around and see if that helps.
Old 04-30-2006, 02:16 PM
dhdenney's Avatar
I mean switch a good one in place of the bad one. They should all be the same.
Old 04-30-2006, 02:17 PM
ReD95LT1's Avatar
well i was just looking at that and mostly all the numbers match except for abs, will this hurt anything if a wrong one is put in place of it?
Old 04-30-2006, 02:18 PM
Chance883's Avatar
I am having a similar problem. The only light that I get is the abs inop light. What would be making that light come on?
Old 04-30-2006, 02:19 PM
ReD95LT1's Avatar
its pretty much just saying that you have brakes just not anti lock i guess
Old 04-30-2006, 02:21 PM
Chance883's Avatar
Oh ok. Well what is going out? Maybe my abs sensor? Dont you have to replace the whole bearing assembly to replace that?
Old 04-30-2006, 02:30 PM
ReD95LT1's Avatar
I have no clue. thats what im hoping to find out
Old 04-30-2006, 02:36 PM
TX RED's Avatar
i think you have replace the whole module ..i have had this problem for about 2years it just means that you have no Anti lock brakes u wont feel anything in normal driving just hard braking
Old 04-30-2006, 02:45 PM
ReD95LT1's Avatar
so would switching different relays hurt anything? like taking the ac compressor relay and putting it in the abs slot, would that hurt anything?
because this might be the problem
Old 04-30-2006, 05:27 PM
redhot lt-1's Avatar
go to each wheel and pull the sensor at the reloctor ring they some times get magnatized and collect the metal shavings from your brakes and give a false reading just clean`em and try it. if that does`nt work take a multi-meter and check the plug at the wheel sensor it should be 5 volts car must be running or switch on if it has 5 volts you my have a bad wheel sensor.
Old 04-30-2006, 08:18 PM
borninatransam's Avatar
go outside with a friend. one of you sit in the car and turn it on. the other go around back. hit the brake and see if the third brake light comes on. if it doesnt then change the bulb that should take care of the abs inop light. try the easiest stuff first then go for the harder stuff.
Old 04-30-2006, 08:23 PM
marcus769's Avatar
If you just have the ABS inop light... Check your tire pressures. That cured mine.
Old 04-30-2006, 08:26 PM
rob97TA's Avatar
mine was turning ont he abs inop light, so i started looking at fuses and what not, and just switched the relay wth something else under there, forgot which one i switched out, but i havent had a problem since
Old 04-30-2006, 11:28 PM
ReD95LT1's Avatar
yeah the brake light works, and i have pulled all the fuses and they are good, i wanted to change the relay with something else under there but wanted to make sure it wouldnt mess with anything else?
Old 04-30-2006, 11:40 PM
Captainofiron's Avatar
The early 4th gens have a problems some times with the speed sensor in the front spindle, if it goes out or starts acting up the ABS inop light goes on and off like that. It happend to me. It also can affect your traction control, it turns it off. Also it could be the speed sensor on the top of the rear axle if your car is equipped. that one also has a bad habit of going out prematurely.
Check those out and if its neither its probably the ABS control module, or even the ABS pump
Old 04-30-2006, 11:41 PM
Yea what he said is what I was refering to
Old 04-30-2006, 11:56 PM
Shackleford's Avatar
When I'm braking, the car will like jerk and there will be a pulse/whatever, and then the ABS INOP light will come on.
Quick Reply: Abs INOP? What the heck?
