'86 Z28 heads on a '98 LS1 TA??? HUH???
I originally thought he was selling a set of LS1s but turns out they are heads off an '86 Z28 which he says will work. Isn't that near impossible or is there really a way to make it work?
Our PMs list is below, starting from bottom to top.(sorry if i wasnt allowed to do that) Any input???
Originally Posted by bad86z28
They will if you happen to have installed an LS1 w/ a 6 speed in it.
Originally Posted by Wicked_Hugger99
You sure heads off an '86maro will work on a LS1 cuz i've never heard of that b4 in my whole life
The heads came off my '86 Z28. They have stock valves in them with Comp 918 springs (good to .600 lift). They will definitely bolt up to your T/A, but you will need the '99 and up center bolt valve covers. I can't say how much power they will gain because I don't have any before and after numbers for the heads. You will probably pick up a good amount. Maybe 30-40 hp. My car put down 350 hp with a 222/230 .534/.544 cam through a choked up exhaust. So I would assume that the heads flow fairly well. I would be concerned as to whether or not these heads will work with your cam. I'm not familiar with the specs of the F14, but the heads have been milled .030. I would do some math to make sure you won't have any PTV problems. I could probably do $480 shipped.
Send pics to hugger1999@yahoo.com please
What kinda car did the heads come off of?? Whats the specs on them as far as valves, springs, etc etc??Will they bolt up tp my 98 TA? Were they ever flow tested?? I have all the usual bolt-ons, LTs w/ xpipe and TDs, F14 232/234 on a 112lsa cam & im at 394rwhp locked w/ a vig3200 thru a 3.73geared 12-bolt tuned by Scott(known as Gomer on the board) Why u selling them? so how much power do you think they'd add? Whats the lowest ud go on them shipped to 36330? Sorry for all the questions but im curious and gotta know.
