View Full Version : I can't seem to lean her out.
98Z28CobraKiller
04-30-2006, 05:56 PM
Ok, I am running the HPT 2Bar SD for the 98's. I have my commanded AFR at 1.13 across the board and am still getting like 11.7 to 12.0:1 AFR's on the wideband. My VE table is at zero at WOT (was positive and kept adding till it zeroed out). Now I have values in the 115 range in 100 Kpa cells over 3K RPM. Any ideas?
98Z28CobraKiller
05-01-2006, 07:11 AM
bump ttt
jimmyblue
05-01-2006, 10:05 AM
Commanded as in, this is what the scanner echoes back
while running? Or commanded, like what is in some tune
table or other? Because there's a lot of modifiers and
layers that meddle, between the tables and the final fuel
multiplier commanded.
foff667
05-01-2006, 10:39 AM
I'd like to see the bin file posted so we can look it over.
white2001s10
05-01-2006, 10:55 AM
Using the factory narrow bands to tune your VE?
horist
05-01-2006, 01:02 PM
perhaps OLFA table is richer than what you are commanding? (PCM will use OLFA if if it's richer than PE)
98Z28CobraKiller
05-01-2006, 04:25 PM
Commanded as in the PE table vs Stoich.
98Z28CobraKiller
I'll post it when I get home.
98Z28CobraKiller
05-01-2006, 04:26 PM
I am using a WB02 but for tunning only. It isn't mine and I have to give it back.
98Z28CobraKiller
05-01-2006, 04:28 PM
I thought that OLFA was only used in Open Loop. I am using closed loop and am just using the wideband temporarly (until I get it all dialed in).
I am borrowing the wideband and have to give it back soon.
horist
05-01-2006, 04:38 PM
oh.. when I saw that you were 11.7-12.0 and wanted to lean out... I assumed you were talkng about open loop
what do the stock O2 sensors show? What are your fuel trims?
foff667
05-01-2006, 05:45 PM
keep in mind wot is open loop...so it still applies...if that olfa table is richer then the pe it wont lean out. At least thats my understanding.
white2001s10
05-01-2006, 07:29 PM
I am just using the wideband temporarly (until I get it all dialed in).
So your narrow bands are still hooked up and operating for closed loop?
98Z28CobraKiller
05-01-2006, 09:25 PM
Follow the link to see the tune.
http://www.hptuners.com/forum/showthread.php?p=38161#post38161
98Z28CobraKiller
05-01-2006, 09:26 PM
Yes.......
98Z28CobraKiller
05-01-2006, 09:31 PM
Appears that the OLFA is at 1.13 which should be about 13.0.
white2001s10
05-01-2006, 09:56 PM
Or more like 12.702:1
When your wideband and narrowbands don't agree then it's time to verify your wideband. If it's okay, then it's time to either fix the problem with the narrow-bands, or simply ignore them.
It sounds like you've just adjusted your high-load VE cells too high based on what your narrow-bands tell you. Personally I don't trust narrow-bands at all.
This is one of the down-sides to using the easy way of VE tuning.
98Z28CobraKiller
05-04-2006, 02:34 PM
http://www.hptuners.com/forum/showthread.php?p=38488#post38488
Follow the link above to the outcome and to view the final tune and log files.
In a nut shell, lowering my VE (as White stated above) I was able to get control over my PE table and get AFR right.
Thanks guys.
white2001s10
05-04-2006, 03:23 PM
That sounds right to me.
If you still find you are getting positive fuel trims in the high-load cells that carry over to WOT, you might consider redefining the boundaries of the high-load cells as was suggested in other threads by Jimmyblue.
98Z28CobraKiller
05-04-2006, 03:42 PM
Please explain or post a link.
white2001s10
05-04-2006, 03:50 PM
http://ls1tech.com/forums/showthread.php?t=440140
might want to pm him.
