Wet-sanded and buffed: 01 White Firehawk!
This took forever to do, but I wet-sanded the entire thing, except for the hood and front nose piece. Here is my process:
1000 grit
1500 grit
"Extra Cut" 3M compound
"Fine Cut" 3M compound
Meguieres swirl remover
For sanding, I used a spray bottle with water and just a drop of dish detergent. If I could do anything over again, I would`ve spent more time with the 1000 grit to try to get it perfectly smooth with no "waves". Also, the more time spent with the swirl remover, the more clarity you get on the finish.
As you can, my process was *very* agressive, and this was on factory paint. There wasn`t one spot where I burned through the clear (no white paint on the pads), much less through the color. I am finding that this "factory paint is thin" thinking is a myth.
Anyway, I don`t think it came out too bad for only my second try.
1000 grit
1500 grit
Originally Posted by crazy3rdgen
wow dave the car looks absolutley sweet. I can't wait to see it in person sometime. I'm still deciding on what beater to get for the winter, has to be white too! hah later
Thanks! Your SS never looked that good when I had it! It looks really good with those Z06 wheels. You`ll have to take that to cruise nights at Ocean City, or to Cecil County sometime so I can see it again!
Originally Posted by TransAm_00
Why would you do that to factory paint,,,,, ESPECIALLY WHITE??????
And why not on the factory finish? The point of wet sanding and buffing is to get the surface as "flat" and scratch free as possible (or make the scratches as small as possible). The depth that you get from a custom paint job can hopefully be made up with Zaino!
Want to come out to NM to do my Firehawk? I have asked about every Paint shop I could out here and none will touch it because "the factory paint is to thin".It Looks great!
Th factory paint thing is BS, I have had aeveryone of my cars wet sanded with the factory paint, as well know of many others.
The factory uses te proper amount of paint and clear, otherwise there would be alot of problems. there has to be a certain amount of clear to get the car to look good, plus the paint is sanded by the factory after it is laid down.
Clear = UV resistance. Clear gives gloss but also protects the (relatively fragile) basecoat from the sun. I don't think it's how thin the factory puts on the clear in respect to wetsanding/buffing, it's the UV protection you lose after sanding it down. It will show up years later if not properly cared for
BTW the car looks great....
