TH400 problems
Is this enough friction material to warant a complete rebuild?
My 60E pan didn,t look that bad when I pulled it and it was toast.
That really does suck.
My advice is to call Carl Rossler, he will build you a kick *** TH400.
My other advice is install this yourself when it arrives and don,t let those hamfisted local automotive hacks at your car no more.
geez, I really hope that you did this all on a visa/master card. I wouldn't even call the shop, just reverse the charges. What a bunch of crap.
If you paid cash, I'd burn down the shop to save other people the same fate.
I'm running a rossler th400 and with the few miles I have on it so far I love it. I see nothing but good comments about rosslers work.
I can't believe how many shitty tranny shops there are. It's not hard to do good work and get good at something. I'm pretty sure a monkey could have built you a better transmission.
Originally Posted by NEVR2ND
So I cut the filter open and found this:
Thanks Vince. I am not sure if it is lint from a rag, or clutch material from the trany.
P.S. The torque converter was bought used from this forum. That is a risc people take when buying used stuff.
one of the best things you can do is to install a 300lb. pressure guage and keep an eye on it. all automatic transmissions are 100% hydraulic and good pressure is the key. good luck
