550 RWHP NA 408 on pump gas???
Old 04-30-2006, 11:32 PM
LostCauseZ06's Avatar
Default 550 RWHP NA 408 on pump gas???
ok.... anybody have some dyno charts??? pump gas.. 408.... naturally aspirated...
what is the current record???? who put down the most?? ?is it possible.... i have a dude that doesnt beleive its possible (ford guy hehe) and i know that it is... so im looking for some proof..
Old 04-30-2006, 11:58 PM
Brandon Boomhauer's Avatar
fairly easy to do, heck you should be close to it depending on how good the heads are.
what do you put down?
A combo very similar to yours with a good intake, good exhaust components should get really really close.
There is a big 408 dyno# thread lurking around too.
Old 05-01-2006, 12:03 AM
https://ls1tech.com/forums/dynamometer-results-comparisons/453367-can-you-guys-post-up-your-408-results-setups-here.html
https://ls1tech.com/forums/dynamometer-results-comparisons/482950-lme-408-et-245cc-head-results.html
dont see the numbers in the original post (maybe im blind)
but they say its 530ish w/out exhaust dropped and 15 degrees of timing.
Old 05-01-2006, 12:23 AM
Flow Wizard
Tony Mamo @ AFR's Avatar
A handfull of AFR 225 402/408 combo's have seen 550. I know Mikey at Rapid did one and Ryne's Z06 on this board has one as well. Both of those are with hydraulic rollers as well and I know there are more but these are the two that come to mind right now. Hell, my 383 almost made that with a small solid roller but it is a very optimized package obviously.
While it's certainly not easy to do, with good heads and the right combination that figure is definately attainable even with the current "cathedral" port designs.
Tony M.
Old 05-01-2006, 04:28 AM
Shorty Director
VINCE's Avatar
How quickly we forget... Below is 2 year old setup..
http://smg.photobucket.com/albums/v2...mparograph.jpg
The above pulls were all done when I had ASP pulley installed. I backed up my numbers at Coastal Dyno several times on pump gas with cool down. At RevXtreme minus ASP pulley I dyno'd 543rwhp on 93 octane with no fan or cool down and slipping clutch. My numbers were acquired via no electric water pump, no short belt mod, and with 6.0L heads.
Old 05-01-2006, 10:01 AM
sweet.. thanks guys.. any more?
Old 05-01-2006, 10:12 AM
so what do you make?
or is it a "in the works" setup?
Old 05-01-2006, 12:35 PM
its definately an "in the works" setup... i still need headers,fast 90/90, injectors, and a dyno tune.. then she will purring like a kitten
i put down 410 RWHP untuned, stock manifolds, stock intake, stock intake manifold, stock paper filter, stock exhaust system, and stock injectors
(i know i know... its very very risky running the car how it is without a tune.. the tune is on the way once the new transmission goes in)
Old 05-01-2006, 12:44 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
Tony M.
thats right Tony, out of the box 225's
Quick Reply: 550 RWHP NA 408 on pump gas???
