WOT Switch help
Old 05-01-2006, 02:37 PM
Brian2006's Avatar
Default WOT Switch help
Does anyone have a picture of a WOT switch installed or possibly online instruction with images? Sorry this is my first nitrous kit and I'm new to this stuff and the directions my kit came with kinda confuses me. If you are wondering this is the WOT switch that came with my NOS 5177 kit
Old 05-01-2006, 03:45 PM
patriotformula's Avatar
Im not sure if I have the same WOT switch, but you have to bend it about 6 different ways and play with it so you can make the throttle turn it on at exactly WOT. Sorry I dont know if that helps.
Old 05-01-2006, 04:48 PM
Lordsauran's Avatar
What exactly do you bolt it on to? I bought the kit used so it was already bent to fit the last car.
Old 05-01-2006, 05:09 PM
Ramshaft's Avatar
i have some pics of one that i bent up for a temp till i got mine from nitrous daves. i posted the pics in one of the other threads. i does not look great but it worked and only took two bends.
https://ls1tech.com/forums/nitrous-oxide/493189-wot-switch-mounting.html
here is the thread hope that helps.
Old 05-01-2006, 08:54 PM
Brian2006's Avatar
https://ls1tech.com/forums/showthread.php?t=493189
OOOOOOOOOOO that makes a lot more sense! Didn't know it bolted on the front of the throttle body thanks man I appreciate it.
My next question is where do you wire everything to? Just into the solenoids wiring?
Old 05-01-2006, 09:05 PM
Ramshaft's Avatar
let me know what all you are wiring up i have a few wiring diagrams that i got when i was installing mine. i might be able to help you out shoot me a pm
