? 98 camaro bracket raceing
Hi, I just bought a 98 Camaro from an auction with the intentions of bracket racing it. Is there any trick to getting these things to run more consistent? maybe a chip or something?
-Also are all 98 camaros witha V-8 a Z-28? Do all have LS1s? Reason I ask is because we got it with no Registration,Plates or Badges & it was previously a Gov't owned car. It ran a 13.85 the other night, but usually runs around Low 14's to high 13's. Problem is it varies about .08 between runs.
any help would be appreciated.
Maybe Coach will see this
Thanks
Thanks
I don't know, It doesn't show any signs of being a cop car. It is dark blue, & it does have about 4 cigarette lighter outlets in the trunk but I don't know if that is factory or not.
What does a bone stock v-8 camaro usually run?
But then I'm just guessing, I haven't bracket raced for years, and only had a hundred or so runs of competition.
I hope that wherever I messed up, someone will correct me because we all want you to do well. Go get me a trophy, damn't.
the reason i knew a guy that worked with H. P.D. cars at his shop . they would bring in aboutone or two cars ,camaros,Ltd,crownvicks,and one rare time a 94 impala.he would work on the oil pumps,water pumps,inj. change some plug wires ,and thermostat. so the cars wouldn't heat up .now they may haven't have done this to yours but if it was a goverment car it may have some mods . as to the cig.inlets they use those for radios, scanners,and other things . as to mods go with msd wires,msd ign.,open up the exhast,headers first.then maybe camshaft,heads and valves,and so on . then happy racing
Thanks
Thanks
Yes, it has an LS1.
Stock cars were rated at 13.9 in the 1/4, but I have seen much better and worse (sadly)
There are no chips for the car, you have to get it tuned manually.
As far as consistency, if it is an Auto, then a good stall and a good set of tires will take care of that. If it is a stick, then just get good at driving.
