Quieted down my bullets!
Old 05-01-2006, 11:28 PM
SUX2BU's Avatar
Default Quieted down my bullets!
Well i have been trying to find a way to have a quieter exhaust but still be straight thru MAX performance. I was going to swap my bullets for some bigger mufflers:https://ls1tech.com/forums/generation-iii-external-engine/496730-borla-xr1-s-dynatech-split-flow-mufflers.html.
Well i threw my T rex in last night and it was EXTREMELY loud. neighbor came out and told to to turn it off, it was almost 11:00.
This morning I decided to try something. I noticed back when i had my electric cut outs that when open it was still quieter than with no cut outs at all. So i figured the butterfly part of the cutout helped cut down the noise a little. Kind of smoothed it out if you will. So i cut a piece of .125" aluminum to two 11" x 3" slabs. i then bweat those into my bullets and put some turn downs on the ends. It helped out ALOT. Its still VERY loud, but its alot quieter than when i first started it last night. It sounds alittle louder than when i had the stock cam, but ofcourse now it has a SICK choppy idle.
Here is a few pics.
Attached Thumbnails Quieted down my bullets!-p5010766.jpg   Quieted down my bullets!-p5010767.jpg   Quieted down my bullets!-p5010768.jpg   Quieted down my bullets!-p5010771.jpg
Old 05-01-2006, 11:29 PM
SUX2BU's Avatar
Here is what it looked like before.
https://ls1tech.com/forums/drag-racing-tech/417401-pics-my-bullets-long-tubes.html
Old 05-01-2006, 11:42 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Lol! Looks quieter now, just from looking at the other one.
Old 05-01-2006, 11:44 PM
SUX2BU's Avatar
i need to hear it after i get it tuned to see if i'm going to keep it like this or buy some mufflers. right now its a bitch to start.
Old 05-02-2006, 12:35 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
that is cause you need to put a cam in it. It knows that you are going to.
That's what she said...
TheBlurLS1's Avatar
I bet its a bitch to start! My F14 would die about 12 times from my parking spot to the street when it was untuned.
I can't wait to see what kinda times you're pulling this year. What size tires are you running and what RPM were you crossing the traps? You had to have been running out of gear with even the stock cam.
Old 05-02-2006, 01:46 AM
SUX2BU's Avatar
Cam is already in.
https://ls1tech.com/forums/texas-members/499434-anyone-feel-last-night.html
Old 05-02-2006, 01:50 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
SQR tuning?
SUX2BU's Avatar
My friend has HP tuners and we raised the idle to 950 real quick. But thats all we could do i had to go to work. I can get it to start on the first try but i have to crack the pedal and SLOWLY get off of it so it stays idling. after that its butter.
I was running on my friends 28's with the stock cam and was crossing the traps at 122 right after my 6,000 rpm shift light came on.
I mostly do 1/8 mile on 26's though cause there are 4 1/8 tracks around here that are open all the time. once i get it tuned i'll have to hit up Ennis to get a 1/4 mile time.
Gotta see if the 26's can even hold this cam.
Old 05-02-2006, 01:53 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
how is the 8.8 treating you on the 60ft times?
Old 05-02-2006, 01:57 AM
SUX2BU's Avatar
consistent 1.50's-1.49's a couple 1.48's. The TQ arm mount was ****, it broke off the first month i had it. but after i welded it back on it was ok. If i had to do it again i'd go with a Strange 12 bolt w/ spool.
Old 05-02-2006, 02:17 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would DD the shyt out of a spool!
Old 05-02-2006, 02:19 AM
SUX2BU's Avatar
Yeah its no wher near what everybody thinks. The only time i notice it is when i park.
Old 05-02-2006, 02:53 PM
Slow Z28's Avatar
I only time I notice is when I move and have to put it, non-running mind you, in a garage by pushing it.. HAHAHa. NO WAY i'll do that again.
But good idea you got there, would be interesting to see how much different a decibel meter would read it
Old 05-02-2006, 02:58 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Lol what is this the mod exhaust section?
Old 05-02-2006, 05:26 PM
Ric
Ric's Avatar
I'd be telling my neighbor to go engage in intercourse with himself if I were you... that'd help out with the whole noise problem. Good idea though on the bullet trick.
Old 05-02-2006, 05:47 PM
SUX2BU's Avatar
SQR tuning?
Yeah thats where i'm going to take it.
Old 05-02-2006, 05:50 PM
SUX2BU's Avatar
Its still just a hair too loud on the highway after about 30 min @ 3,500- rpms.
I think i'm going to buy some Magnaflow 4" x 9" mufflers to swap out for the bullets.
Old 05-02-2006, 07:01 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Still need to get that video issue worked out.
Old 05-02-2006, 09:24 PM
Ric
Ric's Avatar
I hear lots of folks on here say they're too quiet, but then that's kinda what I'm angling for. Once I get another OEM catback, I'll tie it in with the one on the car for an "OEM" true dual exhaust, and I'll likely run Magnaflow 6" round mufflers out the back.
They'll definitely quiet your car down.
