fuel injectors
Old 05-02-2006, 10:34 AM
J_BAT's Avatar
Default fuel injectors
what size fuel injectors does a stock lt1 have, and is it worth gettin higher cc ones or do i need to get a whole fuel system, or is it not even necessary like would i notice a difference?
Old 05-02-2006, 10:45 AM
blkchevyz's Avatar
94+ have 24# injectors.
they will supply enough fuel for most bolt ons... once you get to forced induction, or decent head cam packages your going to want to upgrade.
the best way to tell if you need them is to look at your injector pulse width through a scanner.
if that gets anywhere near or over 100% you need bigger injectors.
Old 05-02-2006, 12:32 PM
J_BAT's Avatar
thanks i have full bolt ons now, would i notice a difference if i got them or would it act the same
Old 05-02-2006, 12:35 PM
blkchevyz's Avatar
as long as your getting enough fuel right now your not going to notice a difference.
