QTP Headers Rubbing!
Guys... just loosen the steering column from underneath the dash. There are 3 or 4 bolts that hold it to the firewall and there is no need to completely remove the bolts. Then have someone use a pry bar to push the steering shaft away from the header. While that person is holding the steering shaft away from the header, go back underneath the dash and re-tighten the steering column bolts. Takes less then 5 minutes. This way you are actually moving the steering shaft away from the header.
I will give that a shot tonight, thanks!
