Pilot Bearing Installation. Ok to tap it in with an impact socket and small hammer?
Just want to make sure it is safe to do this or do I need to rent a tool to press the pilot bearing in there.
Thanks
Thanks
Originally Posted by xaon
one side has a chamfer around the inside of the bearing... that side goes towards the transmission.
I put my new one in the exact way my original was in there.
The "2 piece" end goes toward the engine. The "flat piece" goes towards the tranny.
Keysplayr.. you're the man! Thanks dude, I appreciate the effort. The funny part is that I just saw 4 posts that says otherwise. Like the dude after you posted the opposite. This is killin me. I'm with you though on this one.
Originally Posted by NHRATA01
Yeah this seems to be 50/50. I put the flat side towards the trans, and chamfered side towards the motor. This is the way the one that was in there before was situated.
If opposite, that is damn strange. Does this mean it does not matter which way the pilot goes? Were you the first guy to change the pilot on your car? Cause I was the first to change mine (original owner), so I am leaning toward the way my drawing shows. If you are the original owner of your car and this is the first time you have changed your pilot, then I guess it does not matter? Stuff like this bothers the hell out of me.
I was just thinking the same thing. I don't think it does matter then. The only reason I was curious is because I saw it in the manual opposite of how I saw it when I pulled it the first time.
I put mine in with the 'chamfered' end towards the transmission, it is there to help guide the tranny back in when you are reinstalling it. Although, it took my dad and I 2 hours to get the tranny back in. Now I am worried. I had a spec stage 2 go bad in 30K miles. I wonder if the shop put it in wrong(the same way I did).
Does anybody a definite answer to this?
Originally Posted by Keysplayr
When you say flat side, do you mean like my drawing? Or opposite of my drawing.
That picture is shoving the chamfered side that goes towards the trans. The chamfer on the bushing is even more visible.
Andrew
So you are saying chamfered towards trans (like I installed mine) and everyone else is saying chamfered end towards motor. Does anyone actually know how or if it matters which way it is installed?
