what would i need
Old 05-03-2006, 07:17 PM
fuseone's Avatar
Default what would i need
what would i need to run a 100 shot of nitrous in my 2001 trans am ws6
Old 05-03-2006, 08:04 PM
Somebody09's Avatar
1. Nitrous kit (from whatever sponsor turns you on the most.)
Pretty long list huh?
and TR55s or TR6s (better choice) if your heart so desires, but I know people who've run wet and dry 100 shots without a plug change.
Old 05-03-2006, 08:45 PM
fuseone's Avatar
what do you mean tr55's or tr6's i dont know what that is. and im asking like would i need to change my clutch or any thing?
Old 05-03-2006, 08:48 PM
code4's Avatar
I'm fairly new at this. This is what I did;
I installed a racetronix fuel pump kit. This may not be nessessary for a stock set up + a 100 shot but I have already done several things, cam, headers etc.
I got a wideband to see where my AFR's are at, again not completely necessary.
I have NGK TR6 plugs gapped at approx .038
I am running the factory stock timing.
I currently have Nitro Dave's Plate kit with a good bottle heater & a MSD
digital window switch.
I had a dry kit before & fried my clutch in one ugly street race, it basically melted, so I went with the RAM HD clutch.
The window switch is set to turn on the nitrous at 3k rpm & off at 5.5 k with 100 shot. It halls ***, very happy with the set up.
Old 05-03-2006, 08:49 PM
Somebody09's Avatar
They're colder spark plugs since nitrous is going to increase the heat and pressure. Your clutch will depend on your driving style... will you lauch with nitrous, spray with it partially engaged, or only spray once you've completely let go? Will you be running sticky tires? I don't drive a manual car (with nitrous on it) so honestly I don't know the finer points. There are several people who do, however.
Old 05-03-2006, 08:56 PM
fuseone's Avatar
i dont have sticky tirers and i will be using after i launch
Old 05-03-2006, 11:03 PM
fuseone's Avatar
ok so would i need any thing else and would the stock clutch hold up
Old 05-04-2006, 01:53 AM
fuseone's Avatar
and the stock rear end hold up?
Old 05-04-2006, 01:59 AM
Restricted User
CAT3's Avatar
fuseone, do you have a stock clutch, is this a manual or automatic torue converter clutch were talking about. C'mon man, if the first post didnt send up a ******* red flag telling you to add more info, be more specific then read my post.
USE THE SEARCH BUTTON
Restricted User
CAT3's Avatar
sit back and think.
Old 05-04-2006, 02:01 AM
Restricted User
CAT3's Avatar
and then post up a more consolidated group of questions with information on your setup, and goals.
Old 05-04-2006, 02:03 AM
fuseone's Avatar
its a m6
Old 05-04-2006, 02:23 AM
Restricted User
CAT3's Avatar
Forgive me, I'm in a shitty mood. Please though, gather the questions you seek answers for and try the search out. If it aint working for you, best bet is to put up the disclaimer "I need to know if..... I tried search but no luck"
