Any idea of whining noise when turning?
Old 05-03-2006, 07:33 PM
619SS's Avatar
Default Any idea of whining noise when turning?
At first it was real bad power steering was leakin so i replaced the power steering pump and resvior and also replaced the rack n pinion but still whines when im turning any ideas? could of one the things i bought maybe bad? any info would thx fellas!!!
Old 05-03-2006, 07:54 PM
Farmer2's Avatar
You may have air in the pump still. Run the steering from side to side all the way but stay off the stops at each extension of turn. (not good for the pump). You also may have to let it sit for a while due to the fluid got airated.
Old 05-03-2006, 09:49 PM
staringback05's Avatar
if its when u turn the wheel all the way, it will usually whine because its at its limit
Old 05-03-2006, 10:00 PM
619SS's Avatar
ya.. but i just noticed it only does it when it gets hot also but whens itz cold itz fine no whining noise plus it does even all the smallest turns !itz wierd!! soo frustrating!!
