my manifold is stuck!! need some advice
Old 05-03-2006, 08:48 PM
1fastz's Avatar
Default my manifold is stuck!! need some advice
i had a weiand intake manifold installed about 2 months ago, now the oil sensor went out so im tryign to take manifold back off but we used tons of rtv sealant and after takign all the bolts off that thold it in place, the manifold is stuck on there!!! anybody have any idea on how to take it off??? it seems like its cemented on there...any ideas or tricks would be of help, thanks guys.
1fastz is offline
Old 05-03-2006, 10:40 PM
SUX2BU's Avatar
Put a long (about 3 ft) bar in the TB opening and pry up.
SUX2BU is offline
Old 05-03-2006, 10:45 PM
Jake the SSnake's Avatar
Give it a light tap w/a rubber mallet from the bottom up if you can get a good shot at it.
Jake the SSnake is offline
Old 05-03-2006, 11:00 PM
9silverbird8's Avatar
^^^what they said.
Why did you use RTV?
9silverbird8 is offline
Old 05-04-2006, 01:23 AM
SSRZ28's Avatar
why was RTV used? its not like the old school manifolds that had the oil galley exposed
SSRZ28 is offline
Old 05-04-2006, 01:31 AM
TX99LS1's Avatar
Rtv??????? Wtf!!!!!!!
TX99LS1 is offline
Old 05-04-2006, 01:37 AM
JMBLOWNWS6's Avatar
Becuase these manifolds are known for vac leaks. SUX2BU is right. Get it off that way. Just use a rag on the inlet to get it off with no marks
JMBLOWNWS6 is offline
Old 05-04-2006, 10:54 AM
SUX2BU's Avatar
SUX2BU is ALWAYS right!
SUX2BU is offline
