texas speed ls6 heads
They dont have a blue stripe on them when i recieved my cam today it had a box of comp 918 springs so does it just now only have the ls6 springs and i have to install the comp 918s
It is not a big deal.
Just get a C-clip spring clamp (old style) and change them.
think of it this way, you got an extra set of LS6 springs for your labor fee. You can sell those and recup some $$.
LS1Tech Premium Sponsor
We install springs on the heads when they're ordered all together!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
I dont understand.
If you ordered the heads and selected the comp 918 springs option they should have came installed and had a blue stripe on them.
If you ordered them seperate then they would not be installed but should have a blue stripe. I think some of the ls6 springs are yellow depending on the year.
If you already received the 918's when you ordered the cam then you must have ordered them separate.
I am confused here.
I am confused here.
