alt pulley?
Old 05-03-2006, 11:42 PM
Dip Stick's Avatar
Default alt pulley?
After 8 pages of searchign I give up )
What is the benfit or loss of putting on the crank UD pulley w/o the alt one?
Thanks and im sure this gets asked a million times sorry
Old 05-04-2006, 08:59 AM
Suspended Sponsor
Synister_Motorsports's Avatar
From my experiences with the LS1 underdrive pulley you should see a 10-12 HP increase, when you put add an overdrive alt pulley you should generally sacrafice about 2 hp.
Thank you
Jonathan Green
Synister MotorSports
Old 05-04-2006, 09:16 AM
jmm98LS1's Avatar
Like said above, 10-12hp is normal from underdrive crank pulley. The only reason you'd need an alternator overdrive pulley is if you have charging issues after the crank pulley install. Being an m6 car, I don't see you having a problem since the manual cars idle faster than an auto. I just have the crank pulley and I don't have any charging issues idling in gear @ 700rpm.
Old 05-04-2006, 09:51 AM
RICEETER's Avatar
dont waste your money
Old 05-04-2006, 10:52 AM
daryl2cb@yahoo.com's Avatar
I agree, I am not knocking the pulley, but there are tons of other things to spend 300 on than that. like headers, cam, heads, real mods.
Old 05-04-2006, 02:43 PM
That's what she said...
TheBlurLS1's Avatar
The pulley is a good mod, and they do not cost $300, even with belts. People most usually wait to put a cam in to do it though, since it has to come off anyway. The overdrive alternator pulley is only needed if you have some damn Baja headlights on your camaro, or a huge stereo with another amp or something. 99% of people get by with just the pulley.
Old 05-04-2006, 03:42 PM
Dip Stick's Avatar
Nods, the car is being worked on by Jeff @ CAM, and he called to let me know the alt pulley was missing
Thus I was wondering what would happen If anything
Thanks for the input
Yea I do have a pretty big aftermarket stereo on the car. I guess I'll have to drive it around for a week to see what happens
Old 05-04-2006, 04:09 PM
Xtnct00WS6's Avatar
What about using an underdrive alt pulley with an underdrive crank pulley? Too much underdrive?
Old 05-04-2006, 04:25 PM
LS1Cryo's Avatar
Sounds alittle overdrive to me.
Old 11-22-2006, 12:18 PM
Somebody09's Avatar
Funny. I don't have Baja headlights, only a Racetronix fuel pump and 42lb injectors. I'm having horrible problems now, especially since it got colder. In 70°F weather though, just 25% U/D pulley seemed ok. This is with an A4 where no idle speeds or anything else changed. Night/Day, head lights on/off, doesn't matter. Stereo? Barely use it, but it's a stock 10 speaker Monsoon. Heat? I wear a coat, so it's always low. My alternator was always fine before this so I won't buy being told that it's all of the sudden going bad. I guess I'm one of the 1% that got shafted by this stupid 10 HP mod.
