anyone going to pocono this weekend may 5-7
Should have made it but one of the Eastern advertizers on this sight stuck it up our butt! At least a month ago the clutch had two balance weights come off the pressure plate and break the starter and the ring gear on the flywheel. They said they would re-balance the pressure plate and send it right back. Not only did we still not receive the clutch back, but they have not mentioned anything about the broken starter or flywheel. You should see how bad the inside of the bell housing looks also. I forgot to mention that the clutch was brand new and failed the first race.
that sux. i didn't make it either although your story is worse than mine. sorry about that. your car must be a freaking animal with all that power. does the iron block mess up the handlinig much? i was gonna race/ co-drive my friends c5 but on the way up, it died. probably fuel pump. so no racey for me either.
here's the vid from me at poc with the rx7 from last august. first day had rain. second day cloudy:
http://207.127.219.37/video/poclong_0002.wmv
