Solid cam help
Solid cam help
Frankly my friend has an engine LS1 346 solid cam from FMS "Allan" anyway.. the problem is we don't know how to adjust the rocker arms and when?? also how to keep the engine in safe?
So we need your helps guys.
Thank you in advance.
LS1TECH Sponsor
to set valves do as follows:
When the exh. starts to open, set the intake.
When the int. starts to close, set the exh.
This will ensure the lifter is on the base circle of the cam.
Sorry for the mistake the cubic inch is 427 not 346.
777. Yes they're adjustable it's a Solid cam not hyd cam.
Bryan@LME. Okay i'm understand you and what's the adjustable number to tug the rockers?
