Extremely quick help...
I'm doing a berger panel right now but have a quick question. After I put the primer on the panel, do I need to sand it down with 1000 grit wet sand? It looks pretty good to me as it is. But, if I still need to sand it down to create a better finish, I obviously will. Also, is the 1000 grit another wet sand procedure? It doesn't say it being so in the hall of fame writeup. Just wondering because if it's wet sanding with 1000, then i'll have to wash it off again which I'm not sure is ok for the primer. Thanks for the help in advance.
sand the primer to 400-600 grit. paint prolly wont stick to 1000-1500 grit. i'd put a few light coats on followed by one or two medium coats, no heavy coats because it'll prolly drip. wet sand extremely light with 1000 then 1500 then rubbing compound.
I'm not gonna wet sand the final coat, I want it as the simple matte finish. I just wanted to know how many coats I should put on being as it looks like there are spots of smoother patches and spots of rougher/more granular looking patches (people who have painted satin hopefully know what I'm talking about).
