I found the car... how much should i put on it? ( spray)
Old 05-04-2006, 09:19 PM
ws6runsTHISshow1288's Avatar
Default I found the car... how much should i put on it? ( spray)
I found my car today. It is a 1999 t/a. It isnt the WS6 but it is the trim before that. I think it is the motor w/ 305? How much wet kit nitrous is reccomended for that car that i can use alot and run safely?
Old 05-04-2006, 09:20 PM
Reject's Avatar
might want to search...there are about FOUR of the same topics on the front page of the nitrous section.
Old 05-04-2006, 09:22 PM
lol ok sorry... i was jsut asking for the 305hp model... ill search
Old 05-04-2006, 10:14 PM
Restricted User
CAT3's Avatar
All models are the same. All trims levels are the same. The all use the same internals and the little "xxx" badge is thrown out the window as soon as the first non-stock part goes on. Other then that look thru search results.
Old 05-05-2006, 06:25 AM
blacktransam's Avatar
GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
https://ls1tech.com/forums/showthrea...o_threadsearch
How to keep an idiot busy for hours..
Old 05-05-2006, 06:49 AM
brad8266's Avatar
150 wet shot is safe. Run NGK TR6 plugs gapped around .035, Walbro 255 fuel pump, window and fuel pressure switch and youre good to go.
Also do a search, this is another one of the beaten down topics here.
