New TT2's are on...Questions..
Old 05-04-2006, 11:23 PM
BLOODTA's Avatar
Default New TT2's are on...Questions..
I just installed my TT2's (9.5s and 11s), hotchkis springs, Spohn double adjustable, and Bilstien revalves. Looks great. We had to cut the whole bumpstop bracket out with a sawsall. Anywho, on the way home, as I applied the brakes, I heard a grinding, it was coming from the front tires, sound like real bad brake pads, could it be the rims rubbing on the front calipers? It only happened when mashing the brakes. So far there has been no rubbing in the rear. I'll have pics after a few days.
Old 05-05-2006, 12:03 AM
transam5.7lt1's Avatar
I just installed Chrome C6 on my trans am, they don't rub or anything... difference is I have 17x8.5 on front, 18x9.5 on rear. I must admit that on the rear, its kind of close to the body, still no rubbing. Good luck on finding whats wrong with yours.
Old 05-05-2006, 05:10 AM
BlackHawk T/A's Avatar
Mine come real damn close to touching the wheel but they don't. There is a chance that yours could, only way to know is to take a look.
Old 05-05-2006, 09:28 AM
Xsta Z 28's Avatar
I have heard of the caliper/bracket contacting TT2's, nothing a little minor grinding can't fix.
Old 05-05-2006, 10:22 AM
RollTideTA's Avatar
Yeah, if its touching, it should be apparent on the inner rim
Old 05-05-2006, 02:50 PM
1 BAD BIRD's Avatar
Damn you Blood I wanted to be the first MRM with TT IIs
Got to have pics!!!!!!!
Bob S.
Old 05-05-2006, 06:56 PM
BLOODTA's Avatar
It only rubs when applying the brakes...Oh, and pics are coming soon...
Old 05-05-2006, 09:33 PM
JonB's Avatar
Yep had the same problem. Pulled out from discount tire with my sweet TT 2's and as soon as I gave it a decent brakeing it started grinding I thought my car was falling apart. I got home and jacked the front up and turned the wheel with my hand and it was touching the caliper brackets. You should be able to mount them where they don't rub but it will still be damn close. Just jack the front up and loosen the lugs and try and get the wheel centered sometimes when tire shops or you are in a hurry it does't get right smack dab in the middle. Usually it does't matter but with these TT 2's it does. I ended up grinding down the bracket some, it was just to close for my taste.
Old 05-06-2006, 12:15 AM
SweeTbone's Avatar
Make it a LOT of pics. High quality if possible. I'm fiending to see them on a MRM.
Old 05-06-2006, 01:49 PM
1 BAD BIRD's Avatar
Here ya go. These will hold ya off
Bob S.
Old 05-06-2006, 02:52 PM
Camaro Z's Avatar
Bob S.
That looks Awsome!
Old 05-06-2006, 03:54 PM
SweeTbone's Avatar
I've already got those ones dammit!!! I need some new material like NOW!!!
Old 05-06-2006, 08:51 PM
1 BAD BIRD's Avatar
TTT Gotta have pics
Bob S.
Old 05-06-2006, 11:22 PM
RrCoX22's Avatar
ya you should be able to tell if they are rubbing by jackin your car up and moving the tire... nothing a little gridding cant take care of
Old 05-06-2006, 11:33 PM
Sold The Fun Stuff :(
josh99ta's Avatar
Everytime I see a damn TTII thread it makes me want them. Bastards!
FWIW, I had a buddy with TTIIs that also had the grinding problem. Seems to be more common than you hear. Easy answer, go with 18s.
Old 05-07-2006, 12:41 PM
BLOODTA's Avatar
Default Pic
Here is the only pic I have so far, the car is really dirty. It's raining here so I can't get good pics yet. Maybe tomorrow...
Old 05-07-2006, 05:29 PM
SweeTbone's Avatar
YES!!! Awesome job.
Old 05-08-2006, 04:08 PM
BLOODTA's Avatar
Pics are here...
https://ls1tech.com/forums/appearance-detailing/503500-pics-my-new-tt2-s-56k-go-dmv.html
