Put the skinnies on (Check it out)
Originally Posted by ls2 bait
ya the 15x10's werent available when i tried to get them either sp i just got the fronts and ill run the m/t dr's i have on the zr1's for now. did u swap studs or do any grinding?
The S60 came w/ bolt in studs, about stock length (little longer), and the front is stock for now. The Arp studs I ordered for the front are back ordered for another 2 weeks. Def. did some grinding in front, not to much, but don't like spacers.
Originally Posted by LS69TA
Yea that does look good. How much are you lowered? I wish I still had my Prostars
Car is lowered w/ Eibach Sportlines in rear ( so about 2 inches ), and the front is a QA1 setup and is adjustable and is about 2 1/4 drop maybe. It is LOW. But nothing really rubs other then the front airdam that pulls air into the radiator, which u can't see anyway. The ground effects/front bumper are yet to hit other then when I put it on a trailor, kinda messed them up, but I well.
