Newbie on Nitrous, input.
Gotta bigger cam, plan on running a Zex Kit (Wet). I already am having a traction problem. Will I need to up my fuel pressure with the cam I'm running on a 100 shot? I have custom tuning, I realize my bosch plugs will have to be changed. Any Ideas for me on this setup.
Restricted User
No, on the LS1 you dont up the pressure. Definately change the plugs...I use NGK TR-6 plugs, starting gap probably around .038" or so for a 100shot. If you want to step it up, then tighten the gap down to .035"-.032". Other than that, use the safety items, look at the FAQ's Sticky up top, and enjoy. Oh yeah, no idea if Zex uses a Nitrous Filter, if not, get one. Make sure the bottle is clean and the siphon tube is securely mounted to the valve before you fill the bottle up. GL
Charlie
Charlie
I have colder plugs, pump, window switch. i dont ever even think of damaging the engine. I am convinced my system is extremely safe. It all depends on the install and safety devices.
Thank you for the great input. Feel better already about running the juice.
I have custom tuning, the threads I'm reading, say not a real good idea to run Nitrous with this setup, unless I tune again for the Nitrous. Input on this please.
Look at my setup, on my sig., am I okay?
