blown 383 costs
Old 05-05-2006, 09:30 PM
Blown383's Avatar
Default blown 383 costs
I finally got the motor back and here is the final breakdown on costs:
Block machining w/hone deck $300.00
Valve job $110.00
Pressure test heads $ 0.00
Cylinder head resurfacing $ 70.00
SCAT/Probe Forged Rotating assembly $1389.00
Upgrade to 4340 steel crank $250.00
Upgrade to 4340 H beams $120.00
Assemble long block $450.00
Complete balance $125.00
Stroker clearance $ 45.00
Canton 15-242T Pan $283.00
Oil pan pick up $ 34.00
Cut dual key on crankshaft + machine front timing cover for BB hub $100.00
Splayed caps + machine work for conversion $275.00
Stroker clearance $45.00
Gasket set $121.00
ARP head studs & main studs $171.00
Melling oil pump $ 0.00
Crane lifters $155.36
Total labor: $1475.00
Total parts: $2523.36
Total + 8.25% sales tax = $4,206.54
Does that sound like a fair price for a fully forged 383 with the 4 bolt splayed main cap conversion?
-B
Old 05-05-2006, 09:57 PM
93turboLT1's Avatar
The assembly and kit sound a bit high...but if you had them purchase it, or just bought a kit, then your going to pay more. You could have saved about 500 on the rotating assembly if you had peiced it together yourself from different suppliers. Other then that looks great for a VERY solid motor.
Old 05-05-2006, 11:03 PM
Blown383's Avatar
I forgot that the price included CC 977 springs & seats, Speed Pro Hell Fire rings, clevite bearings, & melling oil pump. They also spent time clearancing the oil pan to clear the dipstick tube....so that almost totals $500.00.
How much power and boost do you think the motor can handle?
-B
Old 05-05-2006, 11:06 PM
aggiez28's Avatar
you need to give some info on the motor before anyone can answer that
brook
Old 05-05-2006, 11:10 PM
Blown383's Avatar
Well the car has the above set of upgrades on the motor and in addition to a set of LE2 heads, a ATI D1 Procharger, a custom Brett Bauer/Lloyd Elliot cam, and finally a FMIC.
-B
Old 05-06-2006, 03:42 PM
streetwarrior96's Avatar
I paid $3300 delivered to my door. (balanced)
This is a swap
Small block Chevy LT1 (92 thru 97) short blocks built with all forged internal components. The blocks are thermally cleaned and magnafluxed to assure their quality and bored, honed and decked with BHJ fixtures to precise specs. They are assembled with SRP forged pistons, Eagle 4340 forged steel crankshafts, Eagle 4340 forged H beam rods, JE plasma moly file fit rings, Clevite 77 HP bearings, Durabond cam bearings, brass freeze plugs and have steel four bolt splayed main caps installed with ARP main bolts. Assembled with Torco MPZ synthetic assembly lube.
Then I added this (I'm sure you know the going rates for these parts) Should be able to turn on Tuesady!!!!!!!!!!!!! Followed by a custom tune from Corey Henderson
AFR LT4 195 CC / 64 CC chamber with rev kit (competition series)
Comp Cams Extreme Energy 510/520 lift 230/236 @50 Lobe 112 (lift rated with 1.5 rockers)
Comp Cams Pro Magnum 1.6 Rockers
Comp Cams Lifters CCA875-16
Aeromotive GM LT- 1 Fuel Pressure Regulators
LT4 Intake
Bosch 30LB injectors
Walbro 255 Fuel Pump
LT4 Intake
ATI Fluidampr LT1 Harmonic Damper
BMR upper & Lower A Arms
BMR K-member
BMR Lower control arms
Sphon Adjustable Torque Arm
QA1 adjustable Front and rear shocks
QA1 300lbs Rated Front springs
NX Nitrous Express up to 250 shot ('I'll probably do 175)
Hooker LT headers with Dynomax 24" Bullet
3.73 Motive Gears
Zexel Torsen Posi
Moser Heavy Duty Axel
Spec Stage 3 Clutch
Spec Billet Steel fly wheel
MSD 6A Ignition Box
MSD Blaster Coil
Taylor Wires
NGK TR6 plug
I've spent a **** load of $$$$
