Vinci Tuner
Vinci Tuner
I just got my Vinci tuner today. They wasted no time getting it to me
I set the tune need to high performance stock cam,and both trans.features to performance. The shifts are very tight. When the car shifts into 2nd it actually throws my head back to the seat and spins tire.
Also, I noticed with the high performance stock cam tune the idle went down a little and it apears to be a little more quieter when cruising on the highway.
I'm trying to find out if i need to do anything with the power enrichment,shift spark advance,and increase engine idle rpm considering the mods i have. Does anybody have any info on these? Thanks, Joe
without having a wideband or on a dyno, it's a guess if you need more/less fuel/timing. you can try each one individually and drive it to see if you 'feel' any difference. you can try the different cam tunes to see how they work with the mods you have. back when i had most bolt-ons and heads with stock cam on the wife's car, i ended up with cam #3 for the tune.
because that particular tune did what was needed. the tunes are a starting point for a cam in that range. then you play around with it from there. you may need to use a different cam #tune to work the best. that's what's good about this tuner. the tunes are super accurate. they get you close. then, you modify from there.
so far i think the tuner is great. everyone says to get a full tuning suit but i dont have time for that right now. the car is running good right now but i think i'll play with the power enrichment a little and maybee idle. thanks for the info;i'm sure i'll have more quistions in the future. i'm all phyced out about getting a cam now
I also have the Vinci Tuner and love it. In before and after drag strip testing et dropped over 3 tenths and car gained 3 mph. I later added +10% spark advance and picked up another 5 hundreths.
what tune are you running on?
