Do i need spacers?
Old 05-05-2006, 09:46 PM
Alpha-Q's Avatar
Default Do i need spacers?
I just wanted to see if my 19's fit on my camaro (Without tires tho) the bolt pattern was perfect.
The rims were touching from the inside. Will i need to put spacers if i slap on some tires?
Old 05-05-2006, 10:54 PM
01 Red WS6's Avatar
Where is it hitting exactly? My 17x11s hit on the bump stop but once I lower the car its fine
Old 05-05-2006, 11:02 PM
Alpha-Q's Avatar
It's touching all the way at the back when i put the rim on.
Old 05-05-2006, 11:38 PM
01 Red WS6's Avatar
Is it the front wheels or the back? How much does it touch? Is it enough that it makes it hard to have the wheel meet up flush with the rotor?
Old 05-06-2006, 10:23 AM
Alpha-Q's Avatar
It's the back ones. Everything is good, it's not touching the calipers. It's the back of the rim thats touching the inner plastic/metal thing.
Old 05-06-2006, 12:35 PM
01 Red WS6's Avatar
The bumpstop maybe? Probably just needs to be ground down a little and once you put weight back on the wheels it probably wouldn't hit anything. Can you take some pictures?
Old 05-06-2006, 01:51 PM
Alpha-Q's Avatar
I'll try get my friends digital camera.
