Turbo ?
Turbo ?
Is there a difference between a turbo from a diesel vehicle and one from gas vehicle ? The reason I'm asking is I told my friend that I was going with a turbo set-up in my 67 RS/SS and he brought back this turbo from his new job at Robertsons Ready Mix as a mechanic's helper. They gave it to him, no shaft play and everything spins freely . Could I even use this :
It doesn't look too bad, but keep in mind a turbo is one of the cheaper parts of a turbo car setup, my turbos total value are less than 10% of the total cost I have into getting my twin turbo setup done.
Originally Posted by deviate42
you couldnt pay me to put that on my car
The looks like an HX35, is that what it is? I think that will be relatively small for your engine, and the turbo is most efficient in the 20+psi range, which I doubt it will produce on your engine. I think that turbo is better matched for a 2-3L engine.
Originally Posted by Poik
Um, why not? Because it needs to be cleaned because it's dirty and has been used?
I dont care if its dirty, but I generally try to stay away from used turbos.
just my opinion.
This turbo is a lot bigger than the pictures show ! I'm not really sure I want to use them though, I mean I don't have a problem using used parts its just I kinda think deviate42 is right about these turbo's boosting around 20psi cause they are built for a way bigger displacement that can push alot of psi with no problem cause they're built for torque to haul stuff !
Guys,
Gas engine turbo's = Diesel turbos with smaller A/R's.
We build turbos here and all the parts are made for diesels. They are just simply packaged a little different for gas engines. Anybody care to guess what a GT42 comes off of?? When Jose told me I laughed...hehe.
Also the turbo you have appears to be an HX or HY35 off a 5.9L Cummins Turbo diesel. Its only a 5Xmm unit. Also Holset's are old designs and spool relatively slow.
Restricted User
yea man, for that just pick up a ^^^ master power t70 -(MPT70), i got mine for about $550 or so, but i had a slight hookup on pricing at the time, it had a polished housing too, blinggg
just my opinion.
just my opinion.
Dont knock used parts! They helped me afford my setup!
Originally Posted by DrTurbo
Guys,
Please do say... id love to know since i have one....
Originally Posted by NOSjohn
A John Deere dual wheel tractor, correct?
Right, I wasn't sure how big they went. Sounds like Jose has you on the ball with turbo knowledge.
