Dual Exhaust setup
Dual Exhaust setup
This is my idea for a setup, throw in any input, or if you have something similar. I am installing Pace Setter LT's. I want to use the Y-pipe that Pace Setter has, but instead of them coming together, making it a dual setup. Right before where the pipe actually comes together, I am cutting it and putting angle pueces in there so both of them point straight back. Then running 2 3" pipes back just outside of the Drive Shaft, and Torque Arm, each one going into a Dynomax Bullet, and turning down infront of the Axle. The car that I want to do this to is a M6, so there is some room to work with.
Instead of cutting them before the form together and putting angle pieces, you should try to incorporate and x pipe the even out the flow and then run the duals to the back. I have always heard that it helps to run and x-pipe with duals.
