Ls1 Edit and shift speed help.
Old 05-06-2006, 04:03 PM
bsmart82's Avatar
Default Ls1 Edit and shift speed help.
I want to be able to down shift into 2nd below 60 mph. It will currently only shift under 50. Help please... The car is a 2000 Z28 A4 w/3.73's.
Old 05-06-2006, 09:40 PM
wait4me's Avatar
Just email it over. Ill fix it for you.. Jessebubb@yahoo.com
Old 05-07-2006, 09:32 PM
wait4me's Avatar
You say it has 373? But the file is set up for 3.23 and 24.9 inch tires.. That would be the exact reason why it isnt downshifting like you like. The file is set to downshift anything below 76 miles per hour.. It is probably just your speedo is way off. Jes
Old 05-07-2006, 10:06 PM
DrkPhx's Avatar
I saw this post and decided to verify my settings (275/35/18 & 3.73 rear) with EFILive and it now calculates a 2.70 % less difference from the current settings. So assuming this is true my speedometer should read a higher mph because the VSS pulse will go from 12806 to 117634, correct? If true, how much mph difference will I see?
Old 05-08-2006, 06:11 PM
bsmart82's Avatar
The file I sent is my original read. I have already changed gear settings...I will send u my current tune...
