Installing new window motors????
Is there anything I need to know about installing a new power window motor???? I heard some people saying that you need some sort of template for drilling out the rivets,,,, is this true.... I am going over my buddys house to install both of them tonight,,,, any help would be greatly appreciated.
assuming its the same as the lt1s take off the door panel and you can look at where the rivets are with an inspection mirror. take a 1/2 inch bit and drill where you think the rivets are. if done right you will expose the head and drill it out. check out shbox.com for a write up with pics
Copy & Paste Moderator
Its in the FAQ in the Stereo & Electronics section.
Here is the specific post:
https://ls1tech.com/forums/showpost....1&postcount=18
BTW, its an easy thing to do (30min - 60min).
My buddy just finished his windows,,, I helped him with his drivers side,,, it was easy,,, he said the passenger side was even easier after doing the first one.... 45 minutes a door.
as far as following instructions, the install was ez.. pictures helped alot finding the rivets. I didnt run into anything that could "cut" me so I dont know about that, and about holding the window up with something, I did... but I didnt haft to. 3 boltz/nutz l8r... done!.. test it with the car ON, it'll move alot better, then just on aux.
TTT
Perfet info.
Good old search function did the trick
