torque amount on pressure plate to flywheel bolts
Old 05-06-2006, 11:08 PM
themack56's Avatar
Exclamation torque amount on pressure plate to flywheel bolts
how much should i torque the pressure plate to flywheel on the ls1 t56
Old 05-06-2006, 11:28 PM
Jimmard's Avatar
http://www.ls1howto.com/index.php?category=1
I think that'll help you out a little bit
Old 05-06-2006, 11:42 PM
1BADAIR's Avatar
don't forget some red loctite too
Old 05-07-2006, 07:16 AM
Keysplayr's Avatar
Pressure plate bolts are 52ft.lbs. for the factory LUK pressure plate. If you are using aftermarket parts, consult the manufacturer for the torque specs. And defo on the red loctite.
Quick Reply: torque amount on pressure plate to flywheel bolts
