True Duals HELP!
True Duals HELP!
Right now I have pacestter LT's then about a foot pipe from autozone then dumped into slp's mufflers then turned down. Which has absolutely no ground clearance whatsoever I need some help on creating some clearance not alot but a little would help. Ill try to get some pics tomm.
How much are you lowered? There is only so much room you can use on these cars, you may have to go with different springs, or just take it really careful driving around uneven roads and speedbumps.
Im not lowered at all im 100% stock. I was jus wondering If i could beat the underneat wit ha hammer or something. I love my duals I always get compliments on the sound. But the clearance sucks..
I need to see a picture, it sounds like you just stuffed a 3 inch pipe on the collector and then the muffler. If this is the case you will have less clearance. The pipes need to be angled up some then bent back so there is more clearance. doing this will give you a little more room, and hell even an inch is alot with TD's. You could rent a welder and do it yourself or take it to a shop and have them bend them correctly
