whats the advantage
whats the advantage
What is the advantage of a cowl hood on a fuel injected vehicle. When the air is grab from the front of the vehicle or does the cowl hood serve another purpose. Thanks And another question on a thunder racing 230 224 on 111 lsa any input.I have a M6 and thought this cam would compliment mid to high range. My goal is 10 sec. N/A
I was thinking that maybe the reverse would help less tire spin off the tree so i would be able to shift like hell the rest of the way. Is it maybe ineed better out the hole gas/clutch technique. So far my best 60' 1.94 on bfg's., small cam and lt's. Also torque arm (slp)
1 Post
no LCA's or relocation brackets?
ok. i do have lca non adj. Im in the process of a new setup hopefully u would be able to drop some knowledge. So far i have bought a 90/90 FAST; Nick Will. took off all the the stupid egr provisions and ac unit.And do u the purpose of a cowl hood on a fuel injectd motor
1 Post
Some would maybe argue that it allows more air to flow around the outside of the engine, and carry away more heat. Which may be true but i doubt it makes any noticibly difference.
yeah that 90/90 is a nice intake manifold, but thats pretty big too, the air can get lazy in there without a decent ammount of duration, What gears do you have? is there any reason that you dont want a larger cam
Really im open to all options.What would u reccommend to get 10's.This is my full setup.
'00 ls1 M6
asp pulley
slp lt's
90/90 (not installed yet)
slp subframes
agx adj. shocks
16" bfg's
slp TA
bmr lca
best et: 12.60 @110 1.94 60'
Thanks for your time
'00 ls1 M6
asp pulley
slp lt's
slp subframes
agx adj. shocks
16" bfg's
slp TA
bmr lca
