Any tips on getting front wheel hub off?
I had to cut 1 stud to remove the wheel thanks to a crossthreaded lugnut that stripped out and another stud was all buggered up. I think the bearing is bad as well so I removed the 4 bolts holding the hub on and it still won't budge. I heated up the steering knuckle and sprayed it with PB Blaster and I see minimal movement when hitting it with a hammer. How do you get the hub off if it's stuck in place like this?
Originally Posted by REDWS6ROCKET
take the rotor and caliper off, remove the 4 bolts, take the electrical connector loose and should come off with a hammer smack on the hub
ask your friends if they have a hub bearing puller. if not try a parts store that rents tools like checker. or if you have the coin, you can track down your local mac, snap-on ect.. dealer and get one.
As my brother said when he pulled my hub for me:
"Oh here's the problem, we just weren't hitting it hard enough, or enough times."
We didn't keep those hubs though.
Seriously they will come off after a while doing what everyone said or if you must, escalate to a better tool.
Yup, just needed a bigger hammer and more time for the penetrating oil to loosen it up. Sometimes the best thing is to walk away from it for a while. Now if I could only find the time to do a drive in the car! Too much yard work, truck work, exercise(biking), fishing and golfing going in with this nice weather.
