Unhappy Hooker !!
Unhappy Hooker !!
Sorry to disappoint some of you, this is about headers only!!
I was driving home last night from the grocery store when I hear a metal ping underneath the car and then a big exhaust leak....I was thinking WTF. I pulled the car into our local Sam's Club, pop the hood and what do I find, you might ask.
A nickel size hole in the top of the first header pipe about an inch away from the head on the drivers side (next to the temp sensor). Unreal!! Needless to say I'm a little ticked off about it.
Yep...I had the same thing happen to me, I removed my AIR and like a week later i kept hearing an exhaust leak getting worse and worse from under the hood. When I found what it was it was to late, the crack was to large to fix......so I broke off the little tube, sanded the ceramic coating off and welded a little square piece of 18 gauge sheet metal over the hole, then I covered it in silicone for good measure and finally wraped that portion of the header with heat wrap.....problem solved. I would have bought new headers, but i just didnt have the money to be doing that. The fix that i did has lasted about 7 months and I have not had any problems yet!
I think that you have the worst luck, and wierdest problems. hope ya get it fixed. thats the problem with modding we just keep dumping more money into them. I might be heading up to the Fort this summer. people still hanging out at Halls.
Yeah, I was actually planning on being up there until this happened......If it were'nt for bad luck I would have no luck at all.... I think it is safe to say that after this.....Nitrous will never be installed on this car, ever!!!
Well, I really dont have the money for new headers either but I'm not dealing with this block off crap anymore....so to eliminate the possibilty of it happening again I ordered the Kook's race headers(non EGR/AIR).
Happened to me also, called hooker and they said too bad so sad.... So when it came time to buy a 90 TB I knew not to go with them. Pretty much lost my buisness for life unless they come out with a bolt on part that adds like 1000hps... Never say never I guess....
I had to wrap a top off of a dole fruit can lid around it with hose clamps till I could get it welded got me home without burning a valve anyway. Just waiting for the other side to pop now.
Originally Posted by conan
That sucks to here. You wont be disapointed with the kook's.
??? on your Kook's, did you have to cut the Y-pipe to fit the catback?? A friend of mine said I would have to cut some of the length of to make it fit.
I wont waste the phone call but I did email them without a response so far. No big suprise there!!
Originally Posted by jay_99z
Same **** happened to me. Hooker longtubes also. I ended welding both sides up. Wish I had gotten them without the air tubes.
That's what she said...
Pacesetters FTW!
I don't think that thing blew off because you had it blocked off. The AIR system has 1-way check valves that would act almost like it was blocked.
I did not have to cut the y-pipe on my friends car when I installed his Kooks headers/catted y. They slipped into the GMMG lllllllllllllllllllllllllllike-a-gloveeeeeee.
Originally Posted by TheBlurLS1
Pacesetters FTW!
I think the weld gave out for some reason...not sure why. A friend just put some Pacesetters in 2 weeks ago and loves them!!
Thanks for the info...hopefully it goes as easy for me since the car is on jack stands....gets annoying when you have to keep sliding underneath the car.
I did the LT's ory and hooker CB at the same time. I didnt cut the Y pipe but I did have to trim the I pipe to get the CB into place. I had my rear end out to paint so I got every thing in place tacked the y pipe and the CB removed the hole thing and welded it all up on the floor.
Thanks, I meant to say the I-pipe(where it fits into the catback) not Y-portion of the pipe. How much did you trim off?? What did you cut it with??
