Front ZR1 offset
Old 05-07-2006, 06:40 PM
bjw2654's Avatar
Default Front ZR1 offset
I ordered 9.5x17 OE Concepts ZR1 with the +56mm offset for the front of my T/A, but they shipped the +38mm. The +38mm are flush with the top-outside of the fender well. I like how the +38 extends out, but for some reason everyone seems to run the +56.
I plan to lower my car and I'm worried about clearing the top of the fender well. Is anyone running the +38 offset on the stock or lowered front suspension?
Old 05-07-2006, 08:03 PM
bjw2654's Avatar
Here's the view from the front.
Old 05-07-2006, 09:25 PM
SUTTERERMAN85's Avatar
it will be fine. i guess that the 56 are more common.
Old 05-08-2006, 09:26 AM
Xsta Z 28's Avatar
I run 38 mm offset wheels. Looks better.
Old 05-08-2006, 01:13 PM
bjw2654's Avatar
Xsta, I think the 38mm look better also. Your cars look lowered, and I assume you don't have any clearance issues. I have the 275 GS-D3 on the fronts, and they protrude over the edge of the rim some.
I'm just concerned that the tire will rub when I lower the car an inch and then hit a bump.
Old 05-08-2006, 01:27 PM
Xsta Z 28's Avatar
Exclamation
Yup, both cars are lowered. Up front, at full turn lock the tire does ever so slightly rub the plastic liner. Out back, the Berger has 9.5" as well and the rear passenger tire does contact the wheel well lip ever so often. The Convertible I have 10.5" wheels, and the rear passenger tire hit the wheel well lip too, so I rolled it.
Heres a pic of where it rubs up front.
Lots more pics in the "Fikse" album accessible below.
Old 05-08-2006, 09:03 PM
bjw2654's Avatar
I checked mine this afternoon, and they rub on the inner shroud as well (no problem). When turned in all the way they also catch the edge of the inner fender well. I think the tread would grab it an break the plastic. It looks like the tire would clear this if the car was lowered.
Old 05-08-2006, 09:22 PM
Strokinit383's Avatar
I also run the 38's. I thought the exact same thing, fills out the fenderwell much better.
Old 05-08-2006, 10:26 PM
01formulafromthebay's Avatar
I also have the ZR1 in a 38mm backspacing on all four corners i like the way thy sit flush with the wheel well
Old 05-09-2006, 10:59 AM
bjw2654's Avatar
Does the Formula bumper wrap around into the wheel well like it does on the T/A? The tire definately rubs on the edge of the plastic tab on my T/A bumper. I'm pretty sure that I could move the wheel well shroud forward for clearance, but the tab would have to be cut off or pinned forward some how.
Old 05-10-2006, 02:39 PM
Xsta Z 28's Avatar
Not sure what you mean can you take a pic of the issue?
Old 05-10-2006, 03:02 PM
skatinjay27's Avatar
i have the 50 offset for the rear and stock ss wheels fro the front dont know what offset they are but i but spacers on the front last week and it looks so much better.
Old 05-10-2006, 06:45 PM
bjw2654's Avatar
You can see where the tire rubbed the dirt off the plastic shroud. The tire also made contact with the painted black plastic. I think the only options are to (1) cut off that plastic "tab", (2) lower the car an inch, (3) listen to it hum every time I turn halfway to lock, (4) exchange the +38's for the +56's.
Old 05-17-2006, 07:11 PM
bjw2654's Avatar
When I drove with the +38's, I never heard them rub and there was no additional rub marks. I think the forward motion applied enough force to give them clearance.
Reguardless, I decided to go with the +56's. I think that the flush fit of +38's actually made the +50 11" rears look small. If only they made a +48, I think it would look perfect.
Old 05-17-2006, 07:24 PM
i agree i had the 38 before i hit a median and hated how they stuck out more/even with the rears, but then with the stock ss wheels they were in too much i put a 1/4"spacers on the fronts and its perfect for me. before the spacers the 275tires look tiny!!!especially with the gsd3's in the back
Old 05-17-2006, 08:32 PM
fastlt1's Avatar
I thought about 38 for the rears and 56 up front.
Old 05-17-2006, 09:02 PM
Z28XTC's Avatar
Hey fast Lt1 I like the video dude!Get some headers,ory and A 150 dry shot and you will probably be in 12s .How did you chop the full second off?
Old 05-18-2006, 06:23 AM
fastlt1's Avatar
Thanks. I just finished my 150 wet shot for this year. Getting my cutout installed today. Track opens this weekend.
Old 05-20-2006, 10:14 AM
Z28XTC's Avatar
Do you mean maf cut out ?And how did you loose that second between trips to the track on your vid.
Old 05-26-2006, 11:08 PM
bjw2654's Avatar
I bet that would look good if you went with 9.5's all the way around. I guess you would lose the ability to rotate the wheels/tires though.
