Connector
Old 05-08-2006, 11:02 AM
Roarin_8's Avatar
Default Connector
Looked under the car today and this is what I saw. Anyone know where to connector goes to? ABS inop light is on, would this connector be for the ABS?
Old 05-08-2006, 01:08 PM
Z28LS1camaroguy's Avatar
did u get under the car and see if there is a female plug where that one plugs in to???
Old 05-08-2006, 01:14 PM
Roarin_8's Avatar
No I just took the picture since I was already dressed for work. I won't be able to get under the car till Saturday.
Old 05-08-2006, 02:12 PM
Roarin_8's Avatar
Ok, found out that the connector is for my ABS. The shop guys said that the straps from the dyno must have pulled the plug out.
Old 05-08-2006, 02:59 PM
Ws6Extreme's Avatar
Wow.... I would make sure they are a little more careful under there..... There are other wires that may not be a merciful next time.....
Old 05-08-2006, 03:04 PM
Roarin_8's Avatar
True.
Old 05-09-2006, 01:29 AM
4ced's Avatar
well, i guess that just reinforces the fact that its better to do everything yourself!
Old 05-09-2006, 12:34 PM
Roarin_8's Avatar
Connected it back, pretty simple. That little red connector was a pain to get in correctly but it only took about 3 min to get it back on. The main connector took 3 seconds.
Old 05-10-2006, 09:25 PM
Charlie Hustle's Avatar
did the brake light or abs inop turn off?
Old 05-10-2006, 10:10 PM
Roarin_8's Avatar
Never had a brake light issue. I haven't started the car after I connected the connector. I'll find out Friday when I go get gas.
