Boosted guys what injectors are you running?
Im about to buy some bigger injectors and a converter box(If I have to) but I dont know what to buy. It seems my Racetronix 50's arent doing the job and I dont know what to buy. Any help ?
Coal Mining Director
If you are boost referenced, 60lb Mototrons will get you to 800rwhp in a manual. I'm at 700 rwhp with them through a T400 at 81% duty at 6500rpm at 74psi fuel (58 base ramps 1:1)
I have my base set to 59 psi. When I hit it,It ramps to about 63 to 65 psi. But my injectors duty cycle is like 120% by 6100 rpm's. So you think the 60 will cure my problem?
Originally Posted by NA$TY-TA
Im running 96#ers.......
harlans Driver box.
Not sure my base FP.. Matt??
Kyle
harlans Driver box.
Kyle
60's Motrons from ECS took me to 632rwhp at 81% DC with no boost reference. I think it runs 54-56psi at WOT. It was running down below 10.0:1 afr at that point as well. I think they can cary you to 700rwhp with no boost reference.
Brett
Brett
Brett
Brett
Originally Posted by DrTurbo
Jose and JAson use the 60 lb mototrons here. So far they have handled 700+ rwhp. You can run very high pressure with them without having them lock up.
