Oil Weight Viscosity and Brand
Old 05-08-2006, 01:04 PM
1QuickBlkZ28's Avatar
Default Oil Weight Viscosity and Brand
This is my first oil change since I've purchased the car, I purchased SeaFaom and as soon as I figure out how to use it I'm adding it to the oil, soon thereafter I'll be getting an oil change. I live in Southern California where the temp range is usually from 60 at night to 100-ish during the Summer. Which oil should I use to get the best efficiency and performance from my 00 Z28? Also it says in the owners manual that oil additives arent needed, but I watched the dyno video form royal purple and the car did gain HP. I read on LS1tech that a good synthetic w/ Lucas would be just as good as the RP is there any truth to that?
Old 05-08-2006, 01:26 PM
todddchi's Avatar
German Castrol Synthetic 0-30w, $4-5 a quart at Autozone, says "European Formula" on the front and "Made in Germany" on the back. That's the best.
Next up more commonly available is Mobil 0-40.
Search "Castrol" or "German" lots of reading to be found.
Old 07-07-2006, 10:54 PM
FireSilverLullaby's Avatar
well I put royol purple racing 41 in mine which is 10w-40
Old 07-07-2006, 11:07 PM
02SS#406's Avatar
Amen, brutha...bargain of the bunch. Stick a larger Wix filter on her, and run 6 quarts.
