Lid Question
Old 05-08-2006, 02:03 PM
MetallicaMatt's Avatar
Default Lid Question
hey guys, finally finished up all my winter mods, and forgot I bought a used SLP Flowpack
The lid doesn't fit very well, which I've picked up as a common problem. The tabs on the back of the lid wont slide on all the way...should I trim some of the smooth bellows?
also the latches wont stay latched, they pop off very easily...maybe pushing back the lid would help?
I was just wondering if anybody came up with any kind of fix?
Old 05-08-2006, 02:06 PM
Z28LS1KID's Avatar
My SLP lid fits great. Alot of people have the same problem with the latches coming loose. Check and make sure that the lip on the front of the lid is inserted into the slot. Once it is, you should have no problem with the latches popping off and it should be real snug.
Old 05-08-2006, 02:29 PM
okay, i'll check it out
looks like i may have to cut some of the bellow?
Old 05-08-2006, 02:32 PM
gnomee's Avatar
Yeah if you have aftermarket bellows or the fernco you may have to trim them up. The lid fits one way and one way only. When I installed my lid with my stock stuff it was fine, when I put the fernco smooth tubes on I had to trim them down so those tabs would slide all the way in.
Old 05-08-2006, 03:03 PM
SUCK MY SS's Avatar
put one on my buddies z28 the other day...at first it seems like it doesnt want to fit...but once u get the tabs to slide in all the slots correctly, fits like a glove....
Old 05-08-2006, 03:57 PM
you2slo's Avatar
put it on without the bellow to make sure it fits. If it does, trim the bellow.
Old 05-08-2006, 04:20 PM
dnm12's Avatar
no trimming of the bellow is neccesary just make sure everything is snug
Old 05-08-2006, 04:46 PM
Silver02TA's Avatar
yep, most people have problems because they aren't pushing it back far enough. edge of bottom should be out farther than the edge of the lid.
Old 05-08-2006, 11:51 PM
snipped the bellows a bit, lid fits
