FFHP Shop Car Dyno results
Old 05-08-2006, 02:48 PM
Demon SS's Avatar
Default FFHP Shop Car Dyno results
Well we finally got our shop car setup and dyno'd ; the setup is
Patriot Stage 2 heads
FFHP Annihilator cam v.2
LS6 Intake
Dynatech Stepped Race headers(open)
30# SVO injectors (stock fuel system other wise)
Moser 12 bolt with 4.33 gears
max rwhp was 453.8
max rwtq was 417.3
very good considering the 12bolt
car is an M6
Old 05-08-2006, 02:56 PM
s346k's Avatar
nice numbers...
but let me guess, you don't release cam specs?
Old 05-08-2006, 03:05 PM
Demon SS's Avatar
cam specs are 232/240 .579/.579 110LSA +2
Old 05-08-2006, 03:18 PM
s346k's Avatar
wow, in that case...those are some badass heads!
i'm guessing that cam peaked ~6,200 and carried to ~6,900?
Old 05-08-2006, 03:27 PM
black_z's Avatar
Have a graph?
Old 05-08-2006, 03:36 PM
Demon SS's Avatar
nice guess!
peak was right at 6200 and power graph was pretty flat up to 6900 were I have my limiter set.
Old 05-08-2006, 03:37 PM
Demon SS's Avatar
Originally Posted by black_z
Have a graph?
yes, but I don't have a scanner
Old 05-08-2006, 03:49 PM
s346k's Avatar
i figured as much with that duration and lsa combo...
i'm going to custom grind something on a tighter lsa with more duration, i am looking for a pretty flat 6-7k and violent power coming on 5-5,500 nice numbers, i wouldn't think that cam would be a big peak number producer, but provide a nice healthy curve...which leads me to believe that the heads are responsible for the peak numbers.
Old 05-08-2006, 04:07 PM
Gunnar@Patriot's Avatar
Congrats on the numbers Scott!! Now get busy on that turbo set up.
Old 05-11-2006, 09:10 AM
UnbelievabLS1's Avatar
Comp Renegade lobes, huh? we were using those lobes over 2 years ago.
Old 05-11-2006, 09:22 AM
KGSloan's Avatar
Nice number
Old 05-14-2006, 03:27 PM
1fastTransAm's Avatar
Location: Chitown-Jax NC-Jax FL-Honolulu-OKC, OK-NOW New Orleans Area
LS6 Intake
max rwhp was 453.8
max rwtq was 417.3
car is an M6
Brad I cant wait to see what mine will be putting out Dyno will be June 3.
